Wheels off of an '06 and on '96
Quick question about rims. There's a set of 18 inch American Racing Special Edition Rims for sale in my town and judging by the pic it looks like a 5 lug, but they came off of a '06 GT. I have a '96 and need a new set of wheels due to a leak in one of my tires and I also use the 5 lug pattern.
Would I be able to use these on my '96?
Thanks for any insight!
-NeL
-NeL
They will work. I have a 96 mustang too. And i have 05 stock 17" rims on mine. But i did have to put spacers on. The rears looked really funny and kinda bad because they are in the fender well by 1/2". and same with the front. And the front will rub on the frame when u make a sharp turn, like into a paking space or etc. I bought 1/2" spacers for front and rear. The back looks awsome. Even with only a stock 8.5" wide rim it fills the wheel well and makes it look a kinda big. the front is kinda to much. its not bad but stick out barely. I would probably go with a little smaller if i could redo it. mabe a 3/8" spacer for the front. And I think i bought mine on ebay through an actual vendor. not anything used.
Make sure if you put spacers on that have studs on them, the 1/2" will, that you have someone push on the brake while you tighten the spacer to the front axle hub. then the same when you put the tire to the spacer. I though it was tight enough when i first did mine and within 10 miles started getting popping and shaking up front. The spacer to the hub was loose. Good luck.
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
