i have a 96 gt with a 4v lincoln motor in it. I am using the gt 19lb/hr injectors in it with a gt MAF. Im looking at some 39 lb/hr injectors and an 03/04 cobra Maf. I realize i would need a tune to prob run these, but are they going to be ok to run on a rather stock motor? Im only asking because i can only imagine im running lean and the 19's are prob gonna be pushed to their max when its tuned. thanks guys
on the older 96-98 coil pack 4v you souhldnt need a tune as the MAF itself is programmed to the size injectors, so as long as you have a set that matches youll be ok.
