S281sc swap??
Old 02-29-2012, 01:03 PM
wylie_87
wylie_87's Avatar
Default S281sc swap??
I have a 2001 Mustang Gt and was wanting to put a 2006 Saleen 4.6L 3 VALVE SUPERCHARGED ENGINE with the 6-speed trans. Can anyone tell me what kind of problems i might run into as far as it fitting? Will the motor mounts and the transmission mount match up? Will i need a custom drive shaft or bigger rear end? I do have the the complete wiring harness as well so im hoping this will be possible without much custom work. If you have any information that can help me it would be greatly appreciated. Thanks
wylie_87 is offline
Old 02-29-2012, 07:27 PM
LilRoush
LilRoush's Avatar
You are about to jump into a bottomless money pit.
Almost nothing will 'bolt up' for you, and it's a wiring headache.
If it's the power you want out of the SC'd 3V motor, it's cheaper to build a 2V to the same power and drop it in.
LilRoush is offline
Old 03-01-2012, 10:51 AM
!KLeech!
!KLeech!'s Avatar
Agreed, itd be easier and cheaper to just strap a blower to your 2 valve.
!KLeech! is offline
Old 03-01-2012, 10:55 AM
Shampue
Shampue's Avatar
Since this is a fresh topic, and to not resurrect an old old topic. I assume its a money pit to swap a 4-spd Auto with a T-56? Just brain storming
Shampue is offline
Old 03-01-2012, 11:11 AM
!KLeech!
!KLeech!'s Avatar
not really, wouldnt really be that much of a difference than swapping out the 5 speed for it
!KLeech! is offline
Old 03-01-2012, 11:12 AM
Shampue
Shampue's Avatar
I mean replacing a 4-spd auto with a T-56.
Shampue is offline
Old 03-01-2012, 07:33 PM
LilRoush
LilRoush's Avatar
Swapping auto to any manual trans is the same amount of work - and done on a regular basis. However the money adds up when you get into 'built' trans or the T56.
LilRoush is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: S281sc swap??
