Speedo Off a Little?
Is it normal for my speedo to read 35 when a radar said I was doing 33. Same 2 miles off at 25. I didn't get a chance to try higher speeds to see if it was off by 2 miles all across the gauge or if it was a percentage off. I have stock size tires and nothing that should change it.
RE: Speedo Off a Little?
Does your car have the original instrument cluster overlay? I replaced the overlay on mine and had a problem getting the speedo correct. Your needle may not be properly installed. If not, your tire size may be incorrect.
Everything is stock except exhaust cat backs. I can imagine 2 miles on a speedo would be perfectly normal but I just wanted to check. My tires are definatly stock size.
