Pypes high-flow cats vs o/r
I currently have the Mac o/r ProChamber with super 40 series flows, stock headers.
Would the Pypes catted h-pipe be quieter than the o/r ProChamber? I would actually prefer it to be quieter because on the highway going 65+ the drone is so loud it feels like I'm just getting back from a rock concert every time. The ProChamber does sound incredible just going around town though.
^+1, the PO of my car had installed pretty much that same setup--but with an o/r H-pipe. It was noisy as Heck and advertising something a bolt-on GT cannot deliver.
I first installed a UPR catted X-pipe which improved the drone a lot, to finally kill it I lost the FlowMaster chambered mufflers and installed a pair of MagnaFlow straight-thrus...
The real cure would be to relocate the mufflers as done on the '05+ models--though there really isn't much space available to do that on our cars...
you will still have drone with the flows with any midpipe. X, H, catted, o/r, doesn't matter. Go with one of the straight-through design muffs. Most of them can be louder under WOT, but actually not all and they have so much less drone when cruising, not to mention you'll gain a couple extra top end ponies over any chambered muff. I highly recommend SLP Powerflo if you have the loot. They are very tame for a straight-through muff.
I actually had thought about this, but they would have to cut into it right? I wouldn't mind if they did have to, but I just want to make sure it doesn't cause problems
I will be planning to get Pacesetter Long tube headers along with a catted BBK X-pipe. (I may do the BBK catted H instead since I think the H sounds better than the X on a 2v)
Anyone have comments or known issues/fitment issues before I start making plans for this? Only thing I know of for now is dropping the k-member and jacking the engine up, as opposed to lifting the engine.
09-24-2015 09:18 PM
JDWalton
09-24-2015 08:47 PM
trashxtrash
09-20-2015 10:49 PM
