clutch change
Old 10-02-2005, 02:58 AM
TheBob98GT
TheBob98GT's Avatar
Default clutch change
hey guys im tryin to decide if i want to install this clutch i got myself. i have a little experince workin on cars. ive done the mid pipe and intake, tb all myself, so i guess its time to step it up a notch. i have all the tools i just need someone to tell me if its a good idea or not to do it myself. i will have a buddy helpin me but he is about as mechanically inclined as i am. so if anyone has experince with do clutches and wut kind of troubles i might run into then please tell me. help me out here guys i dont want to have pay someone else to install somethin on my car. thanks
TheBob98GT is offline
Old 10-02-2005, 08:30 AM
02StanGT
02StanGT's Avatar
Default RE: clutch change
The two bellhousing bolts at the top of the engine, can be some tough SOBs. The "hidden" starter bolt. There are three bolts, the last one has to be had by feel only. Its not really a difficult job, just time consuming. Make sure to get a new flywheel or have your current one resurfaced. Go ahead and change the throwout bearing and pilot bearing. Before tightening down the pressure plate, make sure the clutch alignment tool is inserted. That way it will save you sometime when the tranny won't slide back into place. [:@]
02StanGT is offline
Old 10-02-2005, 09:25 AM
04BlueGT
04BlueGT's Avatar
Make sure you have a Haynes manual on hand. It will give you the step-by-step process for the clutch. Ditto on the alignment tool. No tool = loads of fun for hours!
Best of luck to you
04BlueGT is offline
Old 10-02-2005, 01:37 PM
GT35thconvertable
GT35thconvertable's Avatar
I changed mine not to long ago and had longtubes on their so I had to take one header off..But dont pay someone to do it break into that thing and do it yourself save you time and money and some pride knowing you can change your clutch in the future.
GT35thconvertable is offline
Old 10-02-2005, 01:43 PM
TheBob98GT
TheBob98GT's Avatar
hey fellas thanks for the replys. its wut i needed to hear if im gonna do this. wear can i purchase haynes manuel? can i get one at an autozone or pep boys auto parts store
Old 10-02-2005, 03:12 PM
mustang_montana
mustang_montana's Avatar
haynes is at any auto parts store. i dont reccomend a spec 3 clutch. the chatter is obnoxious.
mustang_montana is offline
Old 10-02-2005, 07:43 PM
02StanGT
02StanGT's Avatar
ORIGINAL: mustang_montana
How many miles have you put on it?
02StanGT is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
MasterLanMan
09-13-2015 08:21 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: clutch change
