check these out...
RE: check these out...
ORIGINAL: Chopper
What else would have to be done to get them to seal.Sounds like headaches in the making to me.Cheap______'s are not good.Good ______'s are not cheap.
ORIGINAL: David_K
"End Holes On Head Must Be Drilled & Tapped To Assure Proper Seal." what the hell does tha mean? you gotta take mr. dewalt to your cylinder heads
On top of everything else, you have to deal with a 3 inch collector not fitting the 2.25 to 2.5 inch pipes common to most mustang parts. You could go with a 3 inch exhaust, but that is too much for what 95% of us have or want. Maybe a late Cobra could use it, but a N/A 2V would lose torque.
Even FRPP ceramic shorties are $335. If it sounds to good to be true, then it probably is.
TfcCDR
09-14-2015 12:08 PM
