Replacing front O2 sensors
Unless you have some type of welded aftermarket exhaust, the mid pipe should just unbolt from the manifolds, then off the cat back. Just make sure to unclip all the o2 censors before dropping it out, they have a plug up the wire a little bit, that's probably the hardest part getting them uncliped.
You might can do it with the mid pipe installed, but it shouldn't take very long to drop the mid pipe, change them, and bolt it back up.
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
