Vacuum hose question
What does the vacuums hose on the passenger side that goes into the fender. I think this hose is the reason my climate control only goes to vent but I don't want to rip the entire hose out without knowing what it goes to
The hose for your HVAC is a thin plastic tube. It starts at the vacuum distribution block next to the brake booster and goes across the firewall towards the passenger side and then into the firewall. The plastic tends to get brittle over time and often brakes. I repaired the one in my wifey’s mustang a few years back with a rubber sleeve with a slightly smaller inner diameter from my local auto parts store.
How could it not have a brake booster? Its a large (usually black) circular thing on the drivers side of the engine bay, which the brake master cylinder is mounted to. If you don’t have a brake booster, then your stopping distance must be horrible on your car.
Then that is probably an aftermarket setup. I’m pretty sure your ride came stock with a vacuum assist break booster. Either way, hydroboost is just another type of brake booster. So you do have a brake booster on your car. Also, what type of brake booster you have doesn’t matter here. Its the location in the engine bay is the important part (on the drivers side of the engine bay on the firewall). The vacuum junction block will be nearby.
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
