Transmission Fluid Temperature Sensor Circuit High Input
Old 11-20-2013, 11:51 AM
ked263
ked263's Avatar
Default Transmission Fluid Temperature Sensor Circuit High Input
hello,, today start raining , and was driving for few hours under the rain ,
anyway, the O/D Green light start blinking .
I read the cods, and found this new one
any idea what to do, ? is it ok to drive it tomorrow to my classes ? or should I call a break down to take it to the garage ?
Thanks
ked263 is offline
Old 11-20-2013, 10:44 PM
petrock
petrock's Avatar
What was the exact code you got? I assume its an automatic transmission, correct?
petrock is offline
Old 11-21-2013, 11:33 AM
Stevo86
Stevo86's Avatar
Your sensor probably shorted itself out and died. Most likely just need to replace it and call it a day.
Stevo86 is offline
Old 11-27-2013, 02:43 PM
ked263
ked263's Avatar
thanks for your answers guys,
and sorry I am late, yea, the car is automatic
the vin number 1FAFP42X53F363604
the problem (according to my mechanic ) is the valve body. I need new one
I found few online but not sure which one , 4R70W 4R75W, and one that said fit mustang and lincon etc.
from my vin , can someone tell me which one to go with , is it ok to go with the lincon one ?
thanks
ked263 is offline
Old 11-28-2013, 03:59 AM
petrock
petrock's Avatar
I don’t see how a mechanical/hydraulic valve body inside the tranny could cause a high input fault in an electronic circuit. Two completely different animals. The computer is expecting some voltage (probably around 5 volts DC) from the sensor but somehow it is considerably higher then that. That indicates a short of some kind.
As for which tranny you have, there should be a sticker or some other kind of indicator on the drivers or passenger side of the transmission above the oil pan that will tell you which tranny you have. Most likely it is a 4R70W, but it could also be an AODE or AOD depending on the year your car was manufactured. They are all very common transmissions that have been used for years in different model fords.
petrock is offline
Tivo304
08-28-2023 12:19 PM
mungodrums
Suspension
05-16-2019 09:36 AM
Pyrate Dave
09-10-2015 07:30 PM
IronRaptor
09-09-2015 08:10 AM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Transmission Fluid Temperature Sensor Circuit High Input
