foggy lights
RE: foggy lights
ORIGINAL: sprostang
Check out www.mdwholsale.com they have a product to clear the cloudy headlights.
RE: foggy lights
Mine were bad also, i got really fine wet sand paper i think like 400 Grit to start with then got to i think it was like 1000 or 2000 Grit then put a coat of wax over them then they will look good, if it is on the inside then use a heat gun and dry them out and let them set for a while. that should help
RE: foggy lights
Here is a great link to help you. I used these directions on my 01' with great results!!!! good luck http://www.mustangevolution.com/arti...htrestoration/
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
