Spark plugs wires n coil packs
I have a all stock 98 Gt and doing a tune up, was going to put in motorctaft double platinum spark plugs and change the coil packs to the Msd coil packs. Not to sure what wires to run with, I was going to go with Ford performance wires, but are the Msd wires better to go with ? Please respond thank you
+1^
What's important is that you get quality parts, and not cheap junk. Ford Racing wires are not terribly expensive, but you can't go wrong with plain old Motorcraft, either. Prestolite makes a decent wireset too.
The one thing that I don't like about the FR wires is how their 9mm size prevents me from using the stock wire separators.
Unless you're going for a 100K change interval, I wouldn't spend the extra $$ for double platinum.
A spark is a spark. And it is widely accepted that copper is a better conductor of electrical current than platinum, iridium or unobtainium.
I use and recommend Autotlite 764's. Copper electrode, replace about every 30K. Set of 8 will run you about $12.
latinheat1018
16
02-13-2019 05:45 AM
DerekShiekhi
04-11-2016 03:43 AM
Springborn
03-19-2016 02:29 PM
