Headlight issue
thx gonna look it over tommorow finally getting little warmer outside ,can get out there and check it out, main thing i have no power at the number 10 and 4 fuse ,so guessing theres a wire broke somewhere to those , just gotta figure out where that power to those two fuses should be comeing from
well it ended up happening again, so i did some wire traceing and found that the old owner had used a quick connect on the main power wire from the headlight switch to the multifunction switch and wasnt makeing contact , reconnected and soldered the wire and heat shrinked it and no problems sence !
uberstang1
Jul 26, 2018 08:23 PM
