Fuel Pump Problems
Old Dec 17, 2018 | 07:40 PM
iang0606's Avatar
iang0606
Unhappy Fuel Pump Problems
I started the car in the supermarket parking lot, then I heard some buzzing, kind of like when you prime the fuel pump, but always on. I drove away and didn’t think anything about it. I got home with an insane smell of burnt plastic/electrical wires, even some smoke inside the interior. Once I shut the car off, I started the car and it ran like crap. Tried a couple more times and now it won’t run. It cranks but won’t start. I don’t hear the fuel pump “buzz” when I turn the ignition, so the fuel pump isn’t working, but do bad fuel pumps smell that bad? Or is it something electrical leading to the fuel pump? Please Help.
EDIT: I was involved in an accident where my radiator broke and coolant sprayed over the engine, I don't think it was enough to cause an electrical problem, but it's been to a shop to get the turn signals rewired due to many burnt wires. Back to what happened today, the interior was smoking and it smelled VERY bad. I was told that since the fuel pump is sealed inside the gas tank, it can't be a bad fuel pump.
Please help a friendly Mustang owner out
Thanks
Old Dec 17, 2018 | 11:18 PM
Urambo Tauro's Avatar
Urambo Tauro
Is there any chance the crash damage got to the CCRM or any of its wiring? An accident could trip the inertia switch in the trunk, but that doesn't seem to follow the sequence of events in your post. Couldn't hurt to check it anyway though. The inertia switch would also be a good spot to check for power, just to see if there's any voltage making its way towards the fuel pump.
Any luck tracing down what was smoking up the cabin? Did any other electrical stuff stop working?
Old Dec 20, 2018 | 12:15 PM
iang0606's Avatar
iang0606
I ended up pulling the interior apart and found many melted wires (bare copper) under the carpet, it was pretty bad. I'm going to replace all the rear wiring probably.
Old Dec 20, 2018 | 01:36 PM
Urambo Tauro
Oh, fun. What caused it though? Oversized fuses?
Old Dec 20, 2018 | 03:35 PM
iang0606's Avatar
iang0606
I have no clue tbh, do you any ideas? The fuses were all the correct sizes though. I found out the previous owner had an aftermarket sub in the back, so probably that had something to do with it.
Old Dec 20, 2018 | 06:02 PM
Urambo Tauro
Hm. The oversize fuse thing was actually my best guess. I figured you were either going to confirm my suspicion, or reveal a much more obvious source of damage that would explain it (you did mention an accident, not sure how extensive the damage was). If there's any leftover sub wiring, that right there might be worth investigating...
Old Dec 21, 2018 | 10:21 AM
iang0606's Avatar
iang0606
The accident was just superficial damage (front bumper and fender), not sure if it would influence some bad wiring problems like this. I'll probably check the fuses again and see.
razman
May 17, 2022 02:23 AM
ComputerGuyKyle
Apr 8, 2015 01:58 PM
angelamarieduncan
Sep 8, 2014 07:29 AM
prtaylor726
Feb 19, 2008 01:39 PM
BPLax21
Sep 6, 2004 07:23 PM
