help, syncros!
Hoe are you shifting, is you're clutch fully depressed? are you power shifting? Not trying to say anything, but I know the clutch has a bit to do with it. I just switched from a 2000 GT to an 03 Mach1, the clutch is much lighter on the mach and ive ground it a couple times from misjudged clutch pedal placement. Ive been drivin' sticks for 7 years now, and you've gotta get used to the cluth every time. But then again, it could be you're synchro's. just trying to throw out some other possible solutions/problems
