Wow (news from friend on 410s+)
RE: Wow (news from friend on 410s+)
i have 4.30's im my daily driver and they are perfectly fine... and why the hell is your friend manually shifting a automatic for.. that should be your first clue not to listen to him..
ORIGINAL: code3GT
You should be fine with an auto. I think with a stock type motor, in a 5-speed you will be really close to redline in 4th gear at the end of the 1/4. I am at about 5900 rpms at the end of the 1/4 in 4th gear.
ORIGINAL: 01GTType
Yea, that's cuz that's the perfet gear for the 1/4. 3.73's will have you out of the meat of your power when going through the trap, because you will have to shift. The 4.10's will have you right where you need to be. If I could do it over again, I'd probably have went w/4.30's myself as they are only 200rpm's more over the 4.10's.
This calculator might help you.
http://www.tchracing.com/tech/gearcalc.php
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
