2000 mustang gt crossmember
My caster is really off in front, the back of the front tires are almost scrubbing the fender and I think its the crossmember that is causing this problem. Ive moved the crossmember all the way to the front already since the bolt holes gives you a little bit of play and still the tires are rubbing the back of the fender well. So I think the only thing left to do is to replace the crossmember or is it? I found a 98 gt crossmember on ebay, however my mustang is a 00 gt so I dont know if it will fit or not. Does anyone know if it'll fit or somewhere I can find one without paying a fortune. Thanks.
RE: 2000 mustang gt crossmember
if i was you, i would get a tubular k-member if money permited... if you have to replace the crossmember, might as well take a hundred lbs off the car while your at it.
has the car ever been in a wreck? any bad potholes?
It doesnt seem like theres any frame damage. Ive put one of those QA1 tubular cross members on my 94 gt before and it fit like ****. I had to do alot of modifications just to get it to fit. Have anyone installed one on thier 99-04 mustang? How does it fit and what brand fits the best? I want to use my original A arms back and I know most of them needs thier own.
