StangSuspensions package info.
Well, i've been looking for a suspension set up recently, and came acrossed stangsuspension bullitt package. Now, i know it comes with swaybars, springs, and tokico's, but how do these compare to my stock setup? Are the sway bars thicker, spring rate different, ect?
RE: StangSuspensions package info.
its the same setup thats on the bullitt (obviously) your gonna see at most a 1/2 inch drop, but all around the kit is a good one. i was thinking about it but i figured i would just go with the eibach pro kit and some fox bodys instead (when i get the $$$)
Like stated before you will see about a 1/2" drop.
As for the sway bars the front Bullitt bar is 28mm and the rear is 21mm which is a V6 bar.
Another option is to buy the Mach1 suspension components and add your own sway bars. On my 2003 GT I used the Mach1 springs/shocks/struts then added a 30mm 03/04 Cobra front sway bar and a 1998 Cobra 27mm rear sway bar. Mine handled damn good for having the stock floppy 4 link.
mungodrums
Suspension
02-09-2016 09:05 AM
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
