Coolant leak..
Coolant leak..
I have a coolant leak right above my 4th cylinder..the coolant leaks into my spark plug hole and causes a bad miss fire..anyways im not sure if its the intake leaking or the hoses by it, the holes dont look like there leaking..but not sure..anybody have this problem? maybe a cracked intake?
RE: Coolant leak..
yeah cracked intake most likely. when you get the new one, change your plugs and wires and clean that coolant out and you'll be fine as far as the missfires. though mine kept missing until i did the engine swap.
