when plastic coolant crossover leaks
RE: when plastic coolant crossover leaks
are you talking about the 4th cylinder..here look at this way..if your standing infront of your car looking at ur engine and its the cylinder farthest away on the left side? Because if its that one..thats a very common spot for a coolant leak on mustangs. Just take the hose off, clean the inside real good, and clean the nipple it goes on with some brake cleaner or something..then put alittle bit of grease on the nipple..just a little bit and put the hose back on and tighten it down good.
if ur standing in front its the closet on the right , im just tryin to figure out if its my manifold or dumb mechanic ive caught them spraying water around that coil before
ORIGINAL: silvergt
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
