Spark plugs... DIY?
Old Jan 6, 2006 | 08:44 PM
Tim37's Avatar
Tim37
Default RE: Spark plugs... DIY?
ORIGINAL: justingt
handscrewing it is a defenite no no also right?
don't quite under stand your questionb there
but i never used power tools on spark plugs a impact can brake the electrod or ceramic. i they are suposed to be torgued but i have never torqued them i just tighten them good not too tight though. and agian use lots of anti sieze.
Old Jan 6, 2006 | 09:12 PM
justingt's Avatar
justingt
i meant just screwing them in by hang
Old Jan 6, 2006 | 09:58 PM
SilverGTV8's Avatar
SilverGTV8
You can do it your self. Check the Bullit Archive for a write up.
I am unsure of your year but judging by your body style. be very careful when doing the plugs. Certain years running windsor heads have issues with plugs blowing out of the head.
On a side note did/have you dynoed with you C&L maf? They have a tendancy to make the car dangerously lean.
Old Jan 6, 2006 | 10:46 PM
HaV's Avatar
HaV
No, dont just hand screw them in. They need to be in a little tighter then by hand.. just dont overtorque them.. they arent the toughest things you will ever install.
Old Jan 6, 2006 | 11:53 PM
shuribob's Avatar
shuribob
Remember to torque the plugs. Yes you can tighten them too much! Not fond of the C&L MAF unit either. When I installed the Kenne Bell I had to replace it because of just the reason SilverGTV8 points out, leaned my fuel out and it was a hard MAF to tune. It was easier and better to just replace it with a Super Chips unit. Good luck.
Old Jan 7, 2006 | 12:12 AM
sickspeedgt's Avatar
sickspeedgt
you won't be able to reach the plugs by hand, they are about 8 inches deep in a hole about 1 1/2 inches wide. thats why you need the extention
Old Jan 7, 2006 | 02:18 AM
bryanec's Avatar
bryanec
I always use a foot long piece of rubber tubing to start the plugs then tighten with an extension. They are easy to crossthread.
Old Jan 7, 2006 | 02:38 AM
kartracer55's Avatar
kartracer55
You can get yourself a spark plug socket from just about anywhere but do the USA a favor and get one thats made in the USA from sears. A bit more expensive, but youll thank me later.
Old Jan 7, 2006 | 03:43 AM
M1ke's Avatar
M1ke
ORIGINAL: bryanec
this is what my uncle did when he put mine in. just some vaccum hose that slips over the plug and drop it in there and hand tighten it with the hose so you dont crossthread, then the spark plug socket on an extension and turn it a little bit more after it starts to tighten pretty good.
Old Jan 7, 2006 | 12:48 PM
StickShifty's Avatar
StickShifty
just dont cross thread them.
Dathan
Oct 5, 2015 05:52 AM
dalehunter
Sep 25, 2015 10:51 AM
lmurf60
Sep 24, 2015 10:07 PM
Emblazoned
Sep 3, 2015 10:45 PM
