Steeda X2 balljoints?
Old 02-08-2006, 07:33 AM
LazrRd00GT
LazrRd00GT's Avatar
Default Steeda X2 balljoints?
When driving my car, it kinda sways in its lane and its almost as if its difficult to keep from slightly moving the steering wheel (like there was play in the steering wheel-back and forth motion) my question is would the steeda x2 balljoints fix it or would a bumpsteer kit fix it? by the way the car is lowered about 1.25 inch with the steeda sports springs.
Thanks - Joey
LazrRd00GT is offline
Old 02-08-2006, 11:45 AM
BraMas
BraMas's Avatar
Default RE: Steeda X2 balljoints?
I would say Yes get all of them things and it will help. Read this it should help. I took it from the 50resto.com website
Any time you alter the height of your ride, as you do when you install lowering springs (like our Steeda Sport Springs), you upset the steering geometry. You can easily bring your front end back into spec with a set of our X5 ball joints. Restore roll center geometry and lower you car's center of gravity.
Steeda bump-steer kit, is highly recommended to prevent bump-steer whenever caster-camber plates are used in combination with the X2 balljoint.
Steeda's X2 Balljoint improves suspension geometry on lowered Mustangs
by raising the spindle relative to the balljoint pivot-point. This raises the roll
center back into the correct range for optimum handling, resulting in
reduced body roll, quicker steering response and improved overall front tire
grip. Steeda's special balljoint reduces the need for oversize front swaybars
and allows the use of lower front spring rates, creating more grip over
uneven pavement and better ride quality.
BraMas is offline
CubanoGT
03-09-2010 08:40 PM
mustang fanatic
02-05-2009 05:16 PM
JHonor
12-08-2005 01:27 PM
GT1999
12-29-2004 06:15 AM
SteedaStud
12-27-2004 09:19 PM
Quick Reply: Steeda X2 balljoints?
