Fluid is leaking from my differential.
I got under my car and I noticed that the oil is leaking from my differential. it looks like it is coming from under the cover maybe gasket? i`m not sure if i can do anything about this myself. but till i find some time to go to the shop is there any way i can add some oil myself ? somehow, i appreciate anyone trying to help my out with this.
ps. i freak out cause i`m low on cash and now that! s*it happens
RE: Fluid is leaking from my differential.
big thx beheivjer, and if I decided to replace the gasket how do I go about that without spilling all the gear oil on myself? does anyone know of a place over the net that would sell this type of gaskets? thanks in advance
[IMG]local://upfiles/11407/53E08F094D4A406691E9E4EA9CDD2B89.jpg[/IMG]
i didnt use a gasket on mine anymore. i use a tube of stuff called "the right stuff" its by permatex and you dont even need the bolts to keep it together when you are done. You can order the parts fromautozone or me if you want i can get the prices and let you know monday if you want. its cheap either way. the trick is to losen the cover bolts and let it drain and the just pull s the bolts and let it drop. let me know
KingRando
10-02-2015 08:06 AM
09-25-2015 06:42 PM
