tach install
tach install
anyone know how hard it is to install a tach. what all is nessesary and what do i have to do. beginer when it comes to wiring so do yall know any place with detailed instructions/ pics. how long would it take
RE: tach install
http://www.uprproducts.com/shopping/shopexd.asp?id=558
a tach adapter is needed on alot of 4.6 cars.
RE: tach install
I recently installed a tach in mine, if it is a 98 you do not need a tach adapter, you wire your positve and negative (battery and a ground) then you wire your illumination into a fuse source that comes on with the key. And last the signal wire will go directly into wire #48 (orange and white) in the computer harness behing the passenger side kick panel, took about an hour and a half to run wires, connect and mount, not bad at all.
09-10-2015 08:39 PM
