Exhaust leak causing problems?
Old Jul 12, 2007 | 08:47 PM
clix813's Avatar
clix813
Default Exhaust leak causing problems?
Well I took my car in to ford and cause the check engine light came on reading that one cylinder is runing lean. I knew I had a bad exhaust leak and they said that was the problem so I bought a new mid pipe with high performance cats to make emissions happy so they are putting that in and he said he thinks it will fix the problem. I didnt think a leak would do that.
Old Jul 12, 2007 | 08:51 PM
blackstallion666's Avatar
blackstallion666
Default RE: Exhaust leak causing problems?
if the leak was before the o2 sesnors it will give them misleading readings possibly causeing lean codes. because if the exhuast leaks before the 02 sensors they will never read the rich or lean mixture that is present.
djbigskrilla
Sep 20, 2022 01:04 AM
overnight89
Aug 22, 2015 09:02 PM
91StangOwner
Aug 20, 2015 11:34 PM
11GTBlu
5.0L V8 Technical Discussions
Aug 10, 2015 05:56 PM
Itstbrown
Aug 9, 2015 03:49 AM
