d/r ?
Old Sep 17, 2007 | 02:48 PM
01snake's Avatar
01snake
Default d/r ?
well since the tire section is dead
what is the biggest tire i can fit on the stock 2001 cobra rims?
also if i got nitto 555r's do you guys take those threw the waterbox or just clean em?
Old Sep 17, 2007 | 02:51 PM
99GTvert's Avatar
99GTvert
is my username.
Default RE: d/r ?
assuming yours are 8 inches wide, you should be fine up to 275.
I have 275/40/17 555Rs, and when I go to the track, I go through the water box. They need a lengthy burnout though.
Old Sep 17, 2007 | 04:13 PM
5speedstang's Avatar
5speedstang
Default RE: d/r ?
yeah you will roll into the water box with those 555r's. a 275 would be the biggest you can go. but the bigest you can go with that irs on a differnt rim is a 305 than you have some bolts that are in the way.
Old Sep 17, 2007 | 08:14 PM
massmustang02's Avatar
massmustang02
Default RE: d/r ?
If it's a
17x8= 275/40-17
17x9= 315/35-17
I have seen cobra guys run those sizes on those respective wheel sizes with the Nitto D/R since it is on the skinnier side. I also think you don't need to do anything with the IRS since you're not running a 10" or wider rim width. If you do go with a wider wheel(10"+) then you would need a 3/8" spacer and maybe have to either swap the IRS bolt for a MM one with a rounded head or filethe headdown.
Old Sep 17, 2007 | 09:22 PM
01snake's Avatar
01snake
Default RE: d/r ?
i plan on going solid axle prolly next winter
MABY this winter if i have enough left over after 150 shot (with every assc. almost)and 4.30's
i hope to hit low 12's
with 460rwhp and 4.30's
antipeterleague
Aug 18, 2015 01:50 PM
mustang430
Feb 3, 2007 06:02 PM
DSTANG02GT
Jan 31, 2007 06:20 PM
Sap
12
Nov 28, 2006 11:15 PM
2000GT4.6
Apr 21, 2004 06:59 AM
