problem with trans swap
hey new here... just swapped my 96 auto trans for a tremec 3650 from an 01... swap was easy and straight forward.. except two little problems... one: i have a spec stage 2 clutch and used a steeda double hook quadrant and cable kit, the clutch dosent grab untill the pedal is all the way up.. i tried adjusting the cable at the fork and the firewall seem to get no change in the clutch grabbing point.. any suggestions? should i swap for a diff clutch cable???
second: i installed a pro 50 shifter.. deff the right one cuz its engraved on the shifter body but even in gear their is like half inch of back and forth play.. really sloppy feeling.. dont know if theirs any other adjustments under the gold ring or not... feels wrong to me.. any help?
musnicki
09-23-2015 07:11 AM
