PCV catch can
ORIGINAL: GhostRider02GT
...and after more research, I should add the catch can to the one from the pass valve cover to the plenum, correct? Because the air flows into the MAF, then into the line from the intake tube to the DS valve cover, down to the crankcase, up the passenger valve cover, then to the *plenum*, correct???
So i tried to do the cheap upgrade tonight and it was a no go. I got a ompressor oil seperator from HD, it has 1/4" fittings. I tried finding brass fittings in the 1/4" threads and a 1/2 ID push on end. No luck with that. So the whole project is stalled. The only fittings I could find were with 1/4" threads, and 3/8 ID pushon fittings. Do I need to get a filter with bigger fittings?
ORIGINAL: 02STALKERGT
POISND U "you have to be logged in to do that"[>:]
This is what I did. Keep in mind it's on the passenger's side for 2Vs....
Parts from Autozone; Campbell Hausfeld #MP5138...$11.99
#MP3314 3/8" hose repair kit...............................$ 3.99
#MP3207 3/8" hose end......................................$ 1.99
3' of 3/8" fuel line hose 1.18 a foot.......................$ 3.54
You'll need 3 black tie straps and some teflon tape which I already had.
Put tape on threads of two 3/8" ends and screw into filter. Check air flow arrow and mount as pictured with two tie straps. I put a piece of doublesided tape between unit and car body for a buffer. Undo hose from driver's side vent, take off large rubber adaptor, slide on new hose with clamp from repair kit, tighten and snap back into valve cover. Run other end to filter and slip it on, no clamp needed, inlet side. Attach the new hose to outlet side of filter and run to hose coming from supercharger back. Splice both hoses together using the brass fitting from the repair kit. Use both remaining clamps on this connection. Be sure to run the middle joint up into the factory hose side and clamp..will fit perfectly. I used the 3rd tie strap to anchor the line along the firewall nice and straight. Thats it! Took 30min to do!
JDWalton
Sep 24, 2015 08:47 PM
