switching heads
Old Dec 6, 2007 | 06:48 PM
stoes's Avatar
stoes
Default switching heads
im thinking about switching out my heads (just won a $1300 parlay). which ones should i look at? i dont have the money to get new cams right now, but while im doing the swap is there any other parts that i need to get? and what kind of power increase would i get?
Old Dec 6, 2007 | 08:55 PM
stoes's Avatar
stoes
Default RE: switching heads
bump
Old Dec 6, 2007 | 10:57 PM
flash20's Avatar
flash20
what type of heads do you got in mind? why not wait and do a set of heads and with blower cams at the same time
Old Dec 7, 2007 | 12:24 AM
Zoie_daGT's Avatar
Zoie_daGT
maybe port and polish the heads you have????
[align=left] [/align]
Old Dec 7, 2007 | 09:01 AM
nathansee3's Avatar
nathansee3
BUMP, Just want to hear a good response. Give this guy a little help.
Old Dec 7, 2007 | 10:19 AM
ben790450's Avatar
ben790450
I ♥ Acer
Patriot stage 2 heads. $1200 out the door
Old Dec 7, 2007 | 11:26 AM
kura's Avatar
kura
You've gotta remember to factor in the parts needed to swap the heads. You're gonna be looking at a pair of headgaskets and some head bolts at least. It's arguable, but still not really a great idea to torque the same ones again. Ford makes a head changing kit that's pretty reasonable. jEEd has dealt with the kit a couple of times if I remember correctly, might wanna shoot him a PM or maybe he'll troll his way in here today.
But new gaskets will run you a pretty penny. As for head recommendations.. My modular was stock, and I never really looked into head choices, so I can't be much help there.
Good luck
Old Dec 7, 2007 | 12:04 PM
GT03 TJS's Avatar
GT03 TJS
With VT going under, the first thing that would come to mind are the Patriot Stage II heads. I dont have experience with them, but I believe ZW99 has patriot heads...try PMing him...
Personally, I dont see the point in swapping ported heads just to use a stock PI cam...but if thats all you can afford, thats what you gotta do...which is probably good anyway. Because with a blower cam/ported heads and a procharger....even at low boost, you'll probably be walking a thin line on the stock internals...
Even just with ported heads and a good tune, I bet you'd be about as high as I would feel comfortable going on a stock shortblock...
Old Dec 7, 2007 | 01:23 PM
stoes's Avatar
stoes
i might just port and polish. what does that cost?
Old Dec 7, 2007 | 05:45 PM
Mark99GT's Avatar
Mark99GT
ORIGINAL: GT03 TJS
Excellent point. I think the P&P heads would be a waste of money since you're already close to the limit of your stock bottom end. Save up for a forged shortblock, you're half way there. If you need to spendsome money, get a set of custom blower cams.
And gambling FTW!!!! Nice job!!!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
mustangheaven
Oct 7, 2015 10:23 AM
Drastang
Sep 30, 2015 03:48 AM
