Nitrous
Old Jan 14, 2008 | 05:09 PM
idcoocheimonster's Avatar
idcoocheimonster
Default RE: Nitrous
Well, when it blows it gets built. I have the money to fix it if it goes. But for the time being, i wanna see if it can pull it off.
Old Jan 14, 2008 | 05:34 PM
fruhdaddy's Avatar
fruhdaddy
Default RE: Nitrous
Its possible you could pull it off..But rebuilding these arent cheap. Im doing it for a second time due to faulty motorcraft parts. My family owns a shop and its still kinda on the hefty side. But you should be fine if you get it tuned for it
Old Jan 14, 2008 | 05:38 PM
wwmost's Avatar
wwmost
Default RE: Nitrous
the reason you WANT/NEEDa tune with a dry kit is because it relies on your fuel pump and injector to supply the needed fuel. i would recomend upgrading your fuel pump for sure if you have to get a dry kit. i would never run nitrous without a tune personally. a dry kit creates a way bigger lean spike then a wet kit does and even with a tuned wet kit, like mine, i still have a lean spike when it hits. i imagine what a dry kit is. because the fuel pump cant react fast anough to supply the fuel. so you are lean for a little which is BAD. really bad especially with nitrous. i had to replace my stock fuel pump with a svt focus with my wet kit because of the spike, i could of kept the stocker but it made my lean spike not as bad and it just gave me the extra sense of security.
Old Jan 14, 2008 | 06:05 PM
idcoocheimonster
Default RE: Nitrous
So basically, i should get a Wet Kit, and a tune? Dyno tunes in thios city are pricy as ****. only THR is around, and we all know how that goes.
Old Jan 14, 2008 | 06:20 PM
inkedup75's Avatar
inkedup75
Default RE: Nitrous
??? just tryin to help ya!
Old Jan 14, 2008 | 06:59 PM
arcticman37's Avatar
arcticman37
Default RE: Nitrous
Just got a wet kit myself cant wait until tune time!!!!
01GT4.6's Avatar
01GT4.6
Default RE: Nitrous
I went over 4 years with a 100 shot of NX with no tune and had no issues.
Old Jan 14, 2008 | 07:06 PM
wwmost's Avatar
wwmost
Default RE: Nitrous
ORIGINAL: 01GT4.6
wet or dry?
Old Jan 14, 2008 | 09:05 PM
01GT4.6's Avatar
01GT4.6
Default RE: Nitrous
wet, as far as I know NX only makes wet kits.
Old Jan 14, 2008 | 09:24 PM
sstang's Avatar
sstang
Default RE: Nitrous
Did you retard the timing or anything?
