how to do a burn out?
alright... i know i know. i've never been to the track and i've never drive hard on my car.
however, i would like to know how to do a burn out with a manual tranny.
Thanks guys.
Thanks guys.
Put car in 1st gear, rev up to like 3500-4500 rpm's then drop the clutch, as soon as you drop the clutch press brake til front wheels stop moving. takes a couple of times to get it right, but you must know you will ruin rear brake rotors if you do this too many times. below I have a vid of when i locked it down for a 1 min. I was about to get some new rubber put on.
umm...dumping the clutch from 3500-4500 is a bad idea without a built rear...you will end up breaking something eventually....and your clutch is going to get toasted....i wouldnt do more than 2500-3000 tops
http://www.americanmuscle.com/brpa9gt.html
with a line lock, just put your brakes on, flip the switch then the front brakes keep pressure until you flip the switch off...no more standing on the brakes and ruining your rear rotors, just let out the clutch and get on the gas like normal
Yes, either a line lock or follow the 1st gear dump procedure someone outlined above. Or you could get an auto! Did a very small burnout the other day with my 7 y/o on board. He thought it was cool as hell. So cool in fact, he went to school and drew a picture of the burnout!
Hope none of the other daddy's are policemen!
jpplaw
Mar 19, 2025 08:53 AM
lincolnshibuya
Dec 8, 2015 04:37 PM
