quick question about wheels
Old Feb 5, 2008 | 10:51 AM
rippy25's Avatar
rippy25
Default quick question about wheels
is it worth sixty more dollars to get 18x10 in the rear or save the sixty to put with something else and get 18x9 all the way around? some pics of staggered stangs would help. Other than saving sixty dollars the only benefit i see in getting 18x9 all the way around is that i can rotate them if i need to. these are my choices. http://cgi.ebay.com/ebaymotors/ws/eB...07539&rd=1
http://cgi.ebay.com/ebaymotors/ws/eB...36802&rd=1
Old Feb 5, 2008 | 11:55 AM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
Default RE: quick question about wheels
If you like the look of wider meats out back then that is completely up to you because the performance benefits are negligible. In fact, widerrims out back would be heavier making them harder to turn. If you believe you'll have problems hooking with tires that fit on a 9 inch wide rim try Mickey Thompson ET Street Radials then see if that doesn't fix your problem.
Old Feb 5, 2008 | 03:22 PM
Kmelfi11's Avatar
Kmelfi11
i hated that gap that the back fender had, hung over the 8in rims by like 3 inches it looked like. With the bigger rims it looks like it should all flush and all
Old Feb 5, 2008 | 03:58 PM
baino's Avatar
baino
If you still want to be able to rotate and fill the fender gap, you could try1" spacers. Name brand aren't very cheap, but I wouldn't trust a crappy one. Just a thought. Also if you get 18x9 all the way around but put a widerdirectional tread on the rear, you can't rotate anyways.
Tivo304
Aug 28, 2023 12:19 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
