stupidity
Old Mar 17, 2008 | 10:50 PM
2000AZ5.0GT's Avatar
2000AZ5.0GT
Default stupidity
okay, so ya'll should have told me that 550rwhp is going to be way tooo much for the street. Today was the first day I went WOT in the car, and lets just say I'm having the thing detuned, basically wasted 1st and 2nd gear, an probably an a quarter of the life of my tires. I can't even imagine you guys with your KB's, way too much torque for me.
I think that 400rwhp and maybe 7lbs of boost is far more than enough for me
Old Mar 17, 2008 | 11:13 PM
Hoppers04Gt's Avatar
Hoppers04Gt
Default RE: stupidity
damn thats some nice numbers. Whats your setup?
Old Mar 17, 2008 | 11:21 PM
califas_1987's Avatar
califas_1987
550 is way too much for the street[8D]
Can't you load different tunes for different occasions? Whats the name of the company that has the bezel and you can change between 3 tunes with a ****?
Get a second set of tires for the track. You've done the work to get the numbers (impressive), you just gotta find a way to put it to the ground now.
Old Mar 17, 2008 | 11:27 PM
2000AZ5.0GT
I'm using a locally built 298CID, with Mahle dished pistons at 8.5:1 compression. Stage II heads, not sure which brand, and comp cam's (I'm pretty sure custom ground), titanium valves and new valvesprings, 60lb/hr injectors and a custom (semi discreet) return style fuel system (uses the stock fuel rail covers)
Vortech T-trim set at 16PSI and 8 rib pulley set-up. Snow performance stage II boost cooler with Stoichiometrically correct 50/50 methanol/water mix.
I believe it's a Borg&Warner performance Built "interceptor" transmision with the AOD gearset (close ratio gears), hardened gears, manual valvebody.
Drop in 9" rear, not sure on the brand, and I don't feel like routing around and finding the brand name. 3.73:1 Final Drive ratio ring and pinion
Tokico adjustable coil overs, full length subframe connectors, custom 8pt roll cage.
I think that's everything, but if I miss something, don't sue me
Old Mar 17, 2008 | 11:29 PM
2000AZ5.0GT
ORIGINAL: califas_1987
Yeah, it is too much for the street. I do have the SCT flip chip, and it has 3 seprate tunes on it, but it's a little more with a blower to reduce the boost. I wish it was like a turbo where I could turn on a boost controller and limit the boost in 1st gear.
I may look into welding in a wastegate set-up, that way I can turn down the boost when I need to, it looks pretty neat
Old Mar 17, 2008 | 11:34 PM
HamMach1's Avatar
HamMach1
Too much??? Don't be a *****! [8D]
JK I wouldn't know... I've never touched the gas pedal of something with that much power
Sounds like you have one menacing GT though! Props!
Old Mar 17, 2008 | 11:50 PM
2000AZ5.0GT
ORIGINAL: Slicktastyk Matt
*****? I don't mind being one if it keeps me alive, that way I get more real p***y
Like I said, I will look into a wastegate set up - that way I can run this tune when I have the nitto's on the back. I'm also having my wheels widened to 13" once I find someone to do it, that should help
This is partly why I laugh at people who have 900+rwhp, I know how worthless 550 is, I couldn't imagine how much you would spin with 900Rwhp
Old Mar 18, 2008 | 12:21 AM
H0SS302's Avatar
H0SS302
ORIGINAL: 2000AZ5.0GT
yea but the people who have mass amounts of power, ALSO have a built suspension to go with it haha
Old Mar 18, 2008 | 12:25 AM
2000AZ5.0GT
well hell, I have zero wheel hop, I don't know what else would be able to get the power to the ground outside of ET streets or something. Hoosiers hook pretty well too, but I only get like 3,000 miles on the street.
Trust me, at 500 rwhp I think it start's to loose it's fun factor, unless you have a 5spd, which of course I'm looking for so I can swap out
Old Mar 18, 2008 | 12:38 AM
Sxynerd's Avatar
Sxynerd
Just flip switch it with a masive de-tune. Retarded to death with make for a slow DD.
