Old Nov 20, 2015, 12:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
advancing spark usuing an sct tuner
Old May 19, 2008 | 02:25 PM
  #21
00raging stang's Avatar
00raging stang
Default RE: advancing spark usuing an sct tuner
well i just tested it out with the spark bumped all the way up, so far it sounds the exact same as it did with the stock tune on it and god what a difference it made.
Old May 19, 2008 | 03:12 PM
  #22
MoKo_04GT's Avatar
MoKo_04GT
enjoy! =]
Old May 20, 2008 | 09:49 AM
  #23
kingofqueenz's Avatar
kingofqueenz
I had a talk with diablo about this, and they said no matter if your running 93 octane, its only safe to bump it up by 2 because diablo is optimized to work with 91. You most likely won't cause any problems bumping it up to hte max, but u will probably be running too rich and you should put it on a dyno.
http://diablosport.com/index.php?nam...;p=40777#40777
Old May 20, 2008 | 09:52 AM
  #24
MoKo_04GT's Avatar
MoKo_04GT
*SiGh*
i was trying to explain that to you earlier, when you were trying to bag on me, and i tried to tell you, that i have SCT and IT IS TUNED for 93!!
YOU have DIABLO....which ISNT. hence why yours doesnt/didnt ping with the timing thing. since its a 91 octane tune and you are running 93 octane!!
Old May 20, 2008 | 10:00 AM
  #25
Kmelfi11's Avatar
Kmelfi11
sooo i shouldnt have my timing all the way up on my diablo?
Old May 20, 2008 | 10:03 AM
  #26
MoKo_04GT's Avatar
MoKo_04GT
as long as your engine isnt pinging then you should be ok.
if you are running too rich, usually you would see some smoke out of the tail pipes.
you can also adjust air/fuel ratio with the tuner to lean it out if it is going rich....but as kingofquuenz stated, this should be done either on a dyno or with a gauge to read your a/f
Old May 20, 2008 | 10:10 AM
  #27
Kmelfi11's Avatar
Kmelfi11
ill prob just bump it down a little to be safe but i can def feel more hp
Old Jul 26, 2019 | 02:33 PM
  #28
2008RedGTCS's Avatar
2008RedGTCS
Originally Posted by kingofqueenz
lol okay, i guess im the only one that thinks putting 2 gallons of 101 octane on a 93 tune is actually gonna do close to nothing?
If I read it right, he's advancing timing on top of setting octane at 93, hence the need to bump octane to avoid detonation. Noob here, might be wrong
duanewalker76
Nov 21, 2008 03:57 PM
00raging stang
19
May 19, 2008 09:00 PM
moosestang
Jun 10, 2007 01:09 AM
White02GT
Aug 5, 2006 01:44 PM
poobank
Jan 13, 2006 01:01 AM
