I'm in the process of doing the PI Swap on my 96 GT, but i'm hand porting/polishing the heads, and adding some Cushman II cams. If you do the swap on a 96-98 you should get up to 260 without aftermarket cams and a port and polish job. If you do cams and p/p job you could see around 300-310 if your lucky with a dyno tune. Good luck I picked mine up on Ebay for 399 with Heads/cams/intake manifold/tb/upper intake/iac valve/tps sensor, and all of the bolts. Ebay is the way to go.
