idle problem
Old Jun 16, 2008 | 12:21 PM
99 GT vert's Avatar
99 GT vert
Default RE: idol problem
thats what i was planning on doing tonight when i got back home
Old Jun 16, 2008 | 02:23 PM
stangman1976's Avatar
stangman1976
the idle screw isnt pre set you have to set the idle yourself!!! it's set good enough to start car and run but after it warms up you must adjust the screw
Old Jun 16, 2008 | 02:41 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Before you adjust anything disconnect the battery for 5-7 minutes to reset the KAM (Keep Alive Memory); particularly since you apparently started the car with the TPS disconnected. [/align][/align]This is where the PCM stores learned values like idle airand short/long term fuel trims. If you didn't do this when you installed the new TB you should have; any time you mess with anything intake related that isthe MAF, or is after the MAF(I.e. that might actually alter airflow or the measurement of same) you should clear the KAM.[/align]
Old Jun 16, 2008 | 02:57 PM
1sloblckgt's Avatar
1sloblckgt
I completely forgot to mention that cliffy... It's almost like second nature when I am working on things related to this. Amazing what you forget just because it's so common.
Old Jun 16, 2008 | 04:14 PM
99 GT vert's Avatar
99 GT vert
when i was changing it out i had the battery off and then i had it off alday yesterday since i didnt go any were so that is reset
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
