OD HELP
Old Jul 17, 2008 | 11:43 AM
  #21
Xemeth's Avatar
Xemeth
Default RE: OD HELP
No, they lose more power through the tranny than the manuals. Also, the shifts aren't as firm since they're controlled by hydraulic pressure. Nothing a shift kit can't fix, though.
Old Jul 17, 2008 | 11:45 AM
  #22
defconfire's Avatar
defconfire
Default RE: OD HELP
i think its partally the gear ratios first is only a 2.84:1 and mostally that you cant launch as well because the torque converter has physical slipping rpm limitations before you will just spin the tires trying to powerbrake.
Old Jul 17, 2008 | 11:55 AM
  #23
steve0914's Avatar
steve0914
Default RE: OD HELP
ORIGINAL: Xemeth
i firmed up my shifts with my tuner, and it was a huge difference, not to mention my shift points i changed...so when i get gears, am i gonna be f*cked by my rmps since i have less gears? or is my mph gonna change at those rpm's?
Old Jul 17, 2008 | 11:58 AM
  #24
defconfire's Avatar
defconfire
Default RE: OD HELP
it will only change speed at the given rpm your shiftpoints will all be the same.
Old Jul 17, 2008 | 12:06 PM
  #25
steve0914's Avatar
steve0914
Default RE: OD HELP
now i am really worries with only three gears, what can i expect to see at say 2500rpms in third gear?
Old Jul 17, 2008 | 12:12 PM
  #26
defconfire's Avatar
defconfire
Default RE: OD HELP
46.6 mph in 3rd with a 4r70w at 2500 rpm
Old Jul 17, 2008 | 12:15 PM
  #27
steve0914's Avatar
steve0914
Default RE: OD HELP
with what gears?
Old Jul 17, 2008 | 12:18 PM
  #28
defconfire's Avatar
defconfire
Default RE: OD HELP
4.10's
If you use the OD you can go 70 at 2500 rpm with those same gears.
Old Jul 17, 2008 | 12:25 PM
  #29
steve0914's Avatar
steve0914
Default RE: OD HELP
i don't understand, now my rpm's are at 2200 in third gear at 50mph, so my mph will actually drop?
Old Jul 17, 2008 | 12:30 PM
  #30
defconfire's Avatar
defconfire
Default RE: OD HELP
With 4.10's and not correct, your speedo will still say you are going 50 at 2200 rpm. But you will actually be going about 41 mph.
those numbers are assuming you are not using OD
