tko500?
Old Oct 8, 2008 | 07:40 AM
Stevecooper's Avatar
Stevecooper
Originally Posted by cliffyk
I would not want a 6-speed in a DD either, it serves no purpose unless you are road-racing, or just like shifting gears. BTW, the T-56 in no stronger than a TKO-600...
This would depend on the T-56 in question. If you are going by the manu's spec sheet the Viper spec T-56 is rated for 650+ TQ this is higher than the TKO's 600's 600TQ rating.
Old Oct 8, 2008 | 10:04 AM
AmericanPowertrain's Avatar
AmericanPowertrain
Former Sponsor
Default First gear and hookin' up.
Can you do a 3650 with the 2.87 1st gear?
I have a slightly modified but highly tweaked tuned '03 GT (260 HP/305 ft/lbs) and find that the 3.38 1st gear is just too low, making it difficult to hook up and then bouncing off the rev-limiter 4 to 5 mS later...
Unfortunately, if you want a different gear set, the 3650 is a poor choice. The stock gear set is the only one available. You can, of course, get the gearing you are looking for in the TKO. Based on our experience at the track, you really don't have too much gear, you have a suspension that is not doing it's job. I would love to sell you a transmission, but my first suggestion is to get the rear sorted out so you can hook up better.
There are guys running our 3650s at the track with 700hp winning with the stock gearing. Sort that thing out so the power gets to the pavement and you will have one wicked ride!
Old Oct 8, 2008 | 10:08 AM
AmericanPowertrain
Former Sponsor
Default Viper vs. TKO
Just a quick note. The Viper t56 has a nominal rating of 650ft-lbs, while the TKO has a constant delivery rating of 600ft-lbs and a static torque rating of 1400ft-lbs. Because different methods are used to measure the strength of the two transmissions, it is hard to make an apples to apples comparison. One thing is for sure; though the Viper has very strong gears and shafts, the TKO has much stronger and more durable small parts, such as forks, pins and synchros, that make it an almost bulletproof assembly. When I sell a transmission to a customer with BONZO power I sell them a TKO, and after selling a couple thousand of them I can say that it is an excellent choice.
Old Oct 8, 2008 | 04:34 PM
Stevecooper
I didn't know that thanks for the info.
red4t8
Forum Issues and Feedback
Jul 28, 2008 04:24 PM
1988GTstang
Jul 14, 2008 10:05 AM
travisl1213
Feb 10, 2008 02:24 PM
sarpicaste
Mustang Videos
Oct 18, 2006 05:33 AM
ryanhewett466
Jun 23, 2006 01:51 AM
