Bosch O2 sensor problems
Old Oct 6, 2008 | 03:52 PM
carlastang's Avatar
carlastang
Default Bosch O2 sensor problems
I recently had a OBD code of "bank 2 sensor 2" which led me to replace the Passenger side post cat O2 sensor. I got a Bosch OEM replacement, and have read that others have had problems with these replacements. Well, the code came back about 2 weeks after the bosch was put in. Any ideas??
Old Oct 6, 2008 | 03:59 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Yeah wrong side there..
Bank 1 is the side where #1 piston is which on a GT is the passenger side.
Therefore Bank 2 sensor 2 is DRIVER SIDE post cat (as you indicated)
Old Oct 6, 2008 | 04:12 PM
carlastang's Avatar
carlastang
well...originally I put the sensor in the driver side location, got the code cleared, and it came back within a day. So the code was the same and a shop stated that it is the passenger side that is bank 2 sensor 2. So I took the sensor out and switched it, the C/E light cleared on its own that time. what do I do??
Old Oct 6, 2008 | 04:35 PM
stangalator's Avatar
stangalator
mil eliminators, i made my own, they have been working for about 500 miles so far
Old Oct 6, 2008 | 05:27 PM
teej281's Avatar
teej281
4.6L Section Moderator
just get an Xcal 3 and turn off the rear o2 sensors and o2 heaters so then if you would go with an o/r midpipe, you would be set. or gears or anything else pretty much.
Old Oct 6, 2008 | 06:12 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Do you have a catted H or X-pipe, or the OEM H-pipe? It could be that the cats are shot.
Also what exact code was it, there are 6 or 7 that reference the rear O2 sensors. Of those 3 or 4 mean that the sensors are fine and there is something else wrong...
Old Oct 6, 2008 | 06:59 PM
carlastang's Avatar
carlastang
I've got the stock H pipe. and actually, I never did look at the exact code. Just what the OBD diagnostic at advanced auto said. But I'll go back and check it out. PS: what kinda performance can I gain with the xcal3??
Old Oct 6, 2008 | 07:09 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
How many miles on your car, what kind of driving (mostly in-town, highway, ???)?
If over 65k and a 50/50 in-town/highway or mostly in-town and the cats could be toast.
If that's the case, and you have to pass inspections, and don't want to hassle with swapping things out at inspection time then get an after-market catted X-pipe. I got my UPR catted X for $300 on eBay. It may well be cheaper than getting replacement cats
But before doing anything get the exact codes, look 'em up here, and get back to us...
luckymckay21
Apr 27, 2007 12:29 AM
99_BLACK_GT
May 17, 2006 10:14 PM
91lxstang
Feb 11, 2006 06:55 PM
94CobraN20
Aug 4, 2005 06:22 PM
katamaster
Jun 27, 2004 08:20 PM
