New to the forums and have a couple questions
Old 12-14-2008, 02:04 AM
tsarp90
tsarp90's Avatar
Default New to the forums and have a couple questions
so to start out, i just bought a used 1996 mustang gt with a little under 100k miles on it. I have only bought some 245/45R18(i think) tires and a K&N CAI.
Ok so to the questions. The shifter seems weird in my opinion. for one it doesn't seem like there is a spring to take it from far left to the center and the one from right to center is really stiff. should i buy a new shifter or is there a way to adjust that? Also with the shifter it doesn't feel like a smooth shift in that it clicks twice as it goes into gear, kinda hard to explain.
With the engine, i think i hear a knock around 3k rpm. I ran premium through it once and it went away for a little bit but now it is back, what can i do to fix that?
I also hear the fuel pump. is that normal or should i buy a new one to make the sound go away?
And finally, there are spots on my windows that i have been told are either acid rain spots or salt water spots. i have tried everything that i though that would work to take them off, including buffing wheel and cleaner. Any ideas?
Thanks
tsarp90 is offline
Old 12-14-2008, 02:31 AM
dimebag
dimebag's Avatar
sounds like its got an old short shifter, just replace it
and sounds like you have a bigger pump
im willing to bet the guy before u had a fast car, returned it to stock and sold it
dimebag is offline
Old 12-14-2008, 01:19 PM
tsarp90
tsarp90's Avatar
any ideas about the knocking or the windows though??
tsarp90 is offline
Old 12-14-2008, 01:53 PM
Chubstang
Chubstang's Avatar
You could try some 50/50 water/vinegar mix on the water spots.
Chubstang is offline
Old 12-14-2008, 02:20 PM
GTRACER88
GTRACER88's Avatar
White Distilled Vinager. Also clay bar works really good. Mothers.
As for the knock does it go from 3k and up? or only at 3k. If it was a rod knock you would hear it the entire time.
GTRACER88 is offline
Old 12-14-2008, 03:36 PM
tsarp90
tsarp90's Avatar
i normally only hear it at about 3k. it varies a little.
tsarp90 is offline
Old 12-14-2008, 05:57 PM
mustang_pa
mustang_pa's Avatar
definitly sounds like the owner before you had some go fast parts on the car. I wonder if the car still has a tune on it and it knocks unless u run 93 octane.
mustang_pa is offline
Old 12-14-2008, 06:39 PM
tsarp90
tsarp90's Avatar
how would i check that?
tsarp90 is offline
Diode Dynamics
28
05-26-2022 12:02 PM
Calizic
08-28-2015 01:46 PM
Soldier GT
08-12-2015 03:46 PM
StangMuscle
08-12-2015 07:27 AM
Quick Reply: New to the forums and have a couple questions
