COMP vs CMS vs HITECH!!!
Id trust what JayC and 01GT4.6 say. I mean i wouldnt go with off the shelf cams like Comps. If i would go off the shelf, it would be CMS because i personally have talked with Jim and he is a very helpful guy and his grinds are supperb
Ok, i quoted this again, just so you could see how what you actually said..
First you said bottom end, then you made mention of the rods..
THat is what i responded to..
Later on you made mention of heads, and valve stability, which of those are the reason that the rods wont go past 6250? which of those have anything to do with the shortblock giving up?
my guess is you tried to bring heads into this to save some face? and make it look like you know what your saying?
Make it look like I know what I'm trying to say? SO I misspoke when I said it just had to do with the rods.
But if I really don't know what I'm talking about, explain to me how the stock shortblock is going to last, on stock 2V heads, with a Cast Iron Crank (which isn't included in any cobra IIRC).
Don't get your panties in a bunch, I'm sure you've misspoken plenty of times. Get over it.
The stock engine isn't going to last long at all at 6500RPM on the stock internals and without ported heads, with only a larger cam.
There, is that better?
junior04
Sep 28, 2015 10:53 AM
