turbo
Old Apr 3, 2009 | 01:16 PM
DarkShadow04's Avatar
DarkShadow04
Default turbo
do you need to change your headers to a certain kind for a turbo or is there a way that my bassani optimum length ceramic headers would be able to work?
Old Apr 3, 2009 | 02:21 PM
fausty's Avatar
fausty
Idk much about turbos but im sure you will need different headers...
Old Apr 3, 2009 | 02:54 PM
blee69mustang's Avatar
blee69mustang
if you do a rear mount turbo set-up you could keep your headers. i've seen a front mount turbo and they kept the stock manifolds, ran more pipe and looked kind in efficient but it works. but best would to get an actual turbo manifold and have it be set up correctly.
Old Apr 3, 2009 | 03:03 PM
fausty's Avatar
fausty
I dont wana look like a tool but i remember reading somewhere that guys were using 4v headers on the 2v.I might just be on crack though.
Old Apr 3, 2009 | 03:40 PM
blee69mustang
idk maybe. they are a little bigger. so ya maybe. do the 4v headers fit on 2v's though?
Old Apr 3, 2009 | 04:15 PM
Blownsvt's Avatar
Blownsvt
i am running the stock cobra manifolds on my setup. not sure if they would work on a 2V though.
Old Apr 3, 2009 | 04:27 PM
GTRACER88's Avatar
GTRACER88
You would have to flip the headers around. Thats if you have shorties. LT are to long.
Old Apr 3, 2009 | 05:28 PM
stangman1976's Avatar
stangman1976
you need turbo headers, different design.
Old Apr 3, 2009 | 05:29 PM
Blownsvt's Avatar
Blownsvt
you don't have to. it is all about how you run the plumbing for it.
Old Apr 3, 2009 | 06:00 PM
stangman1976
unless you can bend you're headers and weld a flange on the stock ones will NOT work. you need turbo headers they have special design to allow turbo's to be mounted stock headers dont have a flange to even mount the turbo to. this is the hardest part to find when doing a turbo install.
