Foglamp switch problem
Old Apr 30, 2009 | 09:01 AM
ironhead99's Avatar
ironhead99
Default Foglamp switch problem
I just bought an 04 GT and there are 3 switches right above the shifter, a rear-defroster, a traction control, and the foglamp switch. The only one that works is the rear-defroster. The traction control switch is always lit up, and the foglamps don't work. Yes, the bulbs are good, they came on once! Any ideas?
Thanks,
Kim
Old Apr 30, 2009 | 09:58 AM
devongarver's Avatar
devongarver
might have better luck in the electronics threads, but if your trac.contr. switch is always lit up, it means its disabled. Mine is like that since i shut it off with a tuner. Might want to check that out. Another possibility since your fogs dont work is that they share a common wire(the two switches that is) which is either not supplying voltage(blown fuse) or not grounded properly(loose ground wire) just my 2cents. good luck!
Old Apr 30, 2009 | 12:22 PM
CrazyDan's Avatar
CrazyDan
check the fuse that's probably the problem, had same problem but on my motorcycle
Old Apr 30, 2009 | 03:55 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Thanks,
Kim
If the t/c LED is on regardless of haw many times you press the switch then it is quite likely t/c was turned off in a custom tune. Can you contact the PO and ask?
The fog lights are powered from 20A fuse #27 in thr battery junction box.
Old Apr 30, 2009 | 09:38 PM
ironhead99's Avatar
ironhead99
Default Thanks
Thanks for the suggestions, I will give those a try!
Kim
2007CalSpec
Dec 13, 2020 11:42 AM
TfcCDR
Sep 14, 2015 12:08 PM
vintageaion
Sep 8, 2015 10:45 AM
zanemoseley
Sep 6, 2015 12:58 PM
whatsup62
Sep 3, 2015 01:38 PM
