Thanks for all the input....Helped out alot...I changed the right front caliper out. Bought at advance auto. 45 bucks plus $25 core charge. Pretty easy job too. The only thing i forgot to do was plug the brake line but i crimped it off with a pair of vise grips. The reason i say this is because wwhen i read more of the book after i was done ( go figure) the book said make sure you plug your line immediatly so air doesn't get back into your abs unit. Said it would require a very expensive tool to bleed. But everything worked out ok...Thanks again everybody.
