Ideas?
A built LSX (if you went n/a lets say) would run approx 8k if you built it yourself, but you would at 600-800rwhp (depending on compression). If you spend 10-15k you could hit 1000 rwhp on race gas (n/a). Im spending about 15k, and it should it over 1000 14lbs or less of boost.
well an LSX can be built out to a 511 cubic inch and you can run ls7 heads (375cfm), so its another deal. N/A generally is way more desirable from a reliability standpoint, but not a streetability standpoint. If you went with a lightweight fox body, you run a stroked 351 or even a stroked 302 (using a sportsman block) w/ nitrous get well into the 9's pretty cheaply, but keep in mind for those time your going want a transbrake.
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
