Wheel clearence question
Hey guys i have a 04 mustang gt and i was wanting to put 10.5 rims with 315's out back but i'm not sure i'll have enough room. I have the borla stinger catback and the clearence looks good on the driver side but on the passenger side i have like an inch of room between the tire and the exhaust pipe, and i have 245's right now. So do you guys think they'll fit or not and are n e of u having the same problem. thanks
if your talking a 17" rim i think ud be fine. if not have the pipe moved inward. 17x9 and 17x10.5 with 275's and 315's respectively are prob the most common wheel/tire setup on a new edge.
im running that combo on my 04 GT with about 1.25" drop, no issues
^ correct
I run a set of 11" wheels with 315's on nearly 2" drop, but required a wee bit of ye ol' hammer and a case of the rolled fenders *Jazzer still thinkin' in a Scottish accent*. I am also running a complete aftermarket suspension and have greater articulation than an OEM Mustang, so need more clearance than most y'all
The off-set of the wheels is going to play a sugnificant role here, so would recommend you run no more than a +28mm wheel in 10.5" with a 6.8" back-space. Will still likely need a little work under there so as not to rub on stuff.
Jazzer
Jazzer
Luke9222
10-22-2015 11:55 PM
