Supercharger install
I have a V2 with 42lb injectors and a Focus SVT. If I was going to do it again, I would put in a larger pump. My Focus pump is at 100 duty cycle around 5,600 RPM and limited my HP gains.
I see in your signature you have underdrive pullies. I do not know why, but everyone says you need to swap back to stock when you go supercharged. maybe someone else can chime in.
Plenty went wrong but the install was still fast.
Down side to a smaller supercharger pulley is that you may get belt slip.
Anyway, once you change the injectors, a tune will need to be on it immediately, it probably won't run without one. My car wouldn't start most of the time, and if I did get it to start, it idled like it had cams and caused a big black cloud shortly thereafter, couldn't rev it past 1200 :P Just did it for fun, even though I knew it washed the cylinder walls a bit. Then again, I have 42# injectors.
I have a V1 with 42 lb injectors and a Ford GT40 pump.
Also, it was very easy to install, me and 2 friends put it on in about 4.5 hours and we had to take it off a few times and readjust. Much easier than I expected.
Galactic
04-29-2019 02:56 PM
Luke9222
10-22-2015 11:55 PM
ernesto-619
09-10-2015 01:32 AM
09-03-2015 07:14 PM
