BBS RS GT wheels. will they fit on a 2002 gt.
I know many people have put bbs wheels on mustangs so i had a question. im looking at a set of bbs rs gt wheels that my buddy is getting rid of off his bmw.The front offset is +35mm and rears are at 25mm. it has 245 toyos in the front and 275s in the rear. i was just curious if these wheels would work or require a spacer or anything on a 2002 mustang gt. thanks to those who provide any information.
I am guessing the width of wheels is 9"s & 10's....?
If so, the fronts are about 3/8" deeper than I like to see and would VERY likely need a spacer to avoid rubbing on sway bar or inside of fender. The rears would be fine and no rubbing at all. IMO, I would not run a spacer up front of that thickness. You would need to replace your lug-bolts as the existing ones are too short.
Again... the above assumes that you are looking at 9"x17"/18" wheels with 35~40 series tires (f). And 10"x17"/18" wheels with 35~40 series tires (r). The bolt pattern needs to be 5x4.5 or 114.3mm so confirm this as well.
Jazzer
Jazzer
thanks tj281. ill take some more pictures of it soon. im at a military base right now just got out of my boot camp and i cant drive or have a car on base till january. ill be home in december so ill get some then. believe me i love my bullitts but i was looking into something unique those in some cases 19s are too big. im just gonna possibly look at saleens either white or black. i got the bullitts to be different. anyways thanks for the input guys.
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
09-27-2015 03:16 PM
