Throwing car in "N" while driving
it explains it alll on the site...as for the engine, run moderate boost and a good tune and you will be fine with the stock bottom end
why only tell him one of the things he would need? i already directed him to where he can get a complete list...then you come in and toss up one thing he needs....you trying to confuse this guy?
http://www.on3performance.com/mustanggt.html
KEY TURBO KIT FEATURES:
* Dyno Tested and Proven Kit To Work and Double The Factory Horsepower
* Maintain Air Conditioning and Power Steering
* All 3" 304 Stainless Steel Tubing, Intercooler Piping and Downpipe
* V-band Connections On the Hotside
* Downpipe o2 Bung Welded for Wideband Use
* Both header to turbo pipes have left and right back o2 bungs as well
* Bar and Plate Intercooler
* Turbo upgrades to Master Power and Turbonetics Turbos Available Details below
* All Hardware For Each Component Supplied In The Kit - INCLUDED
* Neatly Packaged to Make Install As Easy As Possible
* Complete Instruction Packet w/ Photos
* Look At Our Photos, Installed and On A Car
We can make the kit complete for our customers but often times customers have some of the parts already. So we sell the kit mostly complete and you can add the last few accessories if need be.
ADDITIONAL PARTS TO COMPLETE THE INSTALL:
* - K-member kit Granatelli kit $650 or QA1 Pro-active Kit $1089
Both include k-member, Tubular A-arms, and Coil-over kit. The QA1 also includes QA1 billet coilover fully adjustable strut and Caster/Camber plates
* - On 3 Performance MAF kit (calibrated to specific injector size) $195
* - Injectors
* - SVT Focus Fuel Pump $139
* - Custom SCT Turbo Tune Chip $325, multiple tune flip chips available, contact us
* - You will want to get a tune after the install, Dynotunemotorsports.com is our Tuner
Turbo Options, Turbonetics or Master power upgrade prices:
* - 70mm Master power Turbo is $279
* - 70mm Turbonetics Turbo is $700
* - Injectors
edit: and from what I have read, it can be somewhat of a pain getting it all to fit right.
