Throwing car in "N" while driving
Old Dec 15, 2009 | 03:43 PM
  #21
02stang2113's Avatar
02stang2113
Im not really worried about gas... i get crappy gas milage and im learning to live with that... unless i wanna switch to a ricer but i dont see that happening in the near future lol
Old Dec 15, 2009 | 03:51 PM
  #22
Tim99GT's Avatar
Tim99GT
Your not going under cover in the ricer world like Hoss?? LMFAO!!!!!
Hoss knows what i'm talking about
Old Dec 15, 2009 | 03:56 PM
  #23
mustangmancp's Avatar
mustangmancp
Yea just keep the auto in drive...ik id forget it was in neutral sometimes lol.
Old Dec 15, 2009 | 07:19 PM
  #24
945LSTANG's Avatar
945LSTANG
Originally Posted by lilcrate
Yeah I'm pretty sure the faster your engine spins, the more gas is being used. That is the purpose of overdrive, if I don't turn overdrive on and cruise around in 3rd, I do believe I would get less MPG than if I turned overdrive on, regardless of my foot pressure. Could be wrong though.
yeah that makes sense. im just referring to when he has his foot completely off of the throttle. i could be wrong as well. who knows? im sure i could find out if i researched around a little, but the fuel mileage difference probably isn't worth the time. lol
Old Dec 16, 2009 | 02:09 AM
  #25
GTRACER88's Avatar
GTRACER88
You wont forget your in neutral as many think. I only do it at lights. Its like manual cars... why leave it in neutral when you can hold the clutch in and have the car in first waiting for the light to change...
Old Dec 16, 2009 | 06:06 AM
  #26
vanquish's Avatar
vanquish
I don't think you save fuel mileage putting the car in neutral coasting down a hill. My wideband maxes lean whether i'm in neutral or in gear if I coast down a hill not pressing the gas b/c the car isn't being supplied with fuel b/c of the momentum from coasting.
Unless this is completely wrong or something is wrong with my car fuel isn't going to the motor when coasting down a hill regardless of being in gear or neutral.
Old Dec 16, 2009 | 07:39 AM
  #27
98redstang's Avatar
98redstang
Originally Posted by Jazzer The Cat
I agree with coming to a complete stop, but think you are better off just leaving it in drive. Sooner or later, you will likely do one of the following:
1. Move the lever too far, by mistake to throw that baby in "R" and go bye bye to the trans or rear end
2. Forget you are in "N" and will attempt to go through the intersection that has turned green just before you get to a complete stop could be a bit embarrasing
3. Do the above, but have music on and not paying close enough attention and gun the gas to show off to the fine looking gal on the corner you are trying to impress with your manly ride
4. You are going through said intersection and need to gun the gas to avoid get plowed by a 3 tractor semi loaded with 10,000 tons of nitroglycerin and, along with 300 innocent victims, among which is the girl you are trying to impress, all die in a huge firey ball that can be seen by the Russian spacemen currently orbiting the earh
Other than those few things... it is pretty much OK
Jazzer
Well thank your for those descriptive, comical and disturbing examples Jazzer hahaha
Old Dec 16, 2009 | 08:01 AM
  #28
ztalon's Avatar
ztalon
I guess you just do what is comfortable and natural for yourself.
I like having my car in gear. I usually downshift through the gears to first or second gear (depending on whether I have to make a full stop or not).
I like downshifting through the gears and have not found it to be a problem for my clutch. I had an original clutch in a 91 Eagle Talon TSi AWD that was still going strong after 17 years (before I sold the car due to salt damage...).
I prefer (and am more comfortable) with having the car in gear with the clutch down. Makes it easy to just take off when the light changes. Now, if I am stuck in a non-moving traffic situation for a while, I will move it to neutral and give my clutch foot a rest.
I never used to put the car in neutral while driving, when I drove an automatic. Just wasn't natural for me to do.
Old Dec 16, 2009 | 08:26 AM
  #29
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
putting an auto in neutral to coast to a stop is a dumb idea....wow
Old Dec 23, 2009 | 07:26 PM
  #30
GStang04T's Avatar
GStang04T
is it bad for your tranny if you have a manual and do coast in neutral then the light turns green and ou have to put it to first gear?
